Electrical circuit for AAR, Where does it trace back to? |
boxsterfan |
Nov 20 2013, 09:10 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So, I have been having what I thought was the problem of a stuck-open AAR.
1. Start car cold 2. Car idles at 1800 RPM during warm-up 3. Car gets warmed up and now starts idling at 3,000 RPM 4. Pull input to AAR and you can feel it is still sucking air in (a ton). 5. Plug the input to AAR and idle drops to 950 RPM. Today, I replaced the AAR (thanks fellow 914world member) with another one. However, the problem/symptom persists just as above. So now I suspect I am not getting power to the AAR so that its little bimetallic strip can be heated up. Where does the power wire for the AAR trace back to in the car (74 2.0L)? How can I test that wire? |
tumamilhem |
Nov 20 2013, 10:12 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
I am currently having this same problem. Hopefully once my AAR valve is fixed (or replaced if can't be fixed), my car will run properly. Also idling at 3000 rpm. When the car gets hot, it struggles to start, if at all due to AAR making the car run lean.
Lo-Fi Version | Time is now: 27th September 2024 - 08:22 AM |
