Straightening a 914, no one around here has a cellette |
FourBlades |
Nov 25 2013, 10:28 AM
From Wreck to Rockin Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I am thinking of putting my IMSA car on a frame jig and having it pulled totally straight. It was pretty hard getting the front suspension to line up when I installed it and the rear needs about an inch of spacers to get the camber right. I have not found anyone nearby that has a cellette bench to do the work. Will shops with other systems be able to get this done? This car has a 10 point roll cage in it, I hope to leave it as it and not cut any, but I guess I can replace some tubes if I have to. Can the experts give me some advice here about how to go about this or if this is a good idea. If you have been through this and don't mind sharing your experiences and costs it would be great. Thanks, John |
FourBlades |
Nov 25 2013, 02:50 PM
Good question Doug. I think it depends on the condition of the car you are starting with. If I had tried to straighten this car before replacing the floors and front of the car it would have just fallen apart. You could put your fingers through a lot of the metal. I tried to do all the repairs as straight and aligned as I could while I went. I don't think the car is twisted or is far out of whack, but if I am ever going to fix it, now is the time, compared to after it is painted. John |
doug_b_928 |
Nov 25 2013, 02:58 PM
Senior Member Group: Members Posts: 703 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Good question Doug. I think it depends on the condition of the car you are starting with. If I had tried to straighten this car before replacing the floors and front of the car it would have just fallen apart. You could put your fingers through a lot of the metal. I tried to do all the repairs as straight and aligned as I could while I went. I don't think the car is twisted or is far out of whack, but if I am ever going to fix it, now is the time, compared to after it is painted. John Thanks, John. Good to know that sometimes it's better to actually do the structural rust repairs before getting the chassis straightened. I suspect that's the boat I'm in. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:21 AM |
