> SMDs in the fog light housing, Final iteration using 90mm circles of SMD 5050 leds
dangrouche
post Dec 28 2013, 07:59 PM
dangrouche
Okay, in my continuing quest to update the incandescent bulbs in our teeners, I changed out the 35 watt bulbs to SMDs in each housing. the cost was minimal of course. I also augmented the light fog grills with "3W White LED Eagle Eye Daytime Running DRL Light Tail Backup Lamp, Stock number# 2XSKU40521" from my my favorite China vendor, Bang good.com. Cost was $5.99 for four of these eagle eyes units; I installed the other pair as daytime running lights on my other car.
I cut out some styrofoam discs (from a take out container) and placed the assembly into the fog light lenses, added some wiring, all WITHOUT cutting any of the OEM wiring.
check it out, one of the pics shows the driver's side bulb with the 35 watt incandescent, compared to the passenger side with the four SMDs.
the pics are misleading. I had the camera flash off and it looks like a blaze, but in person, you see eight bright dots, of the same color as DRLs that you see on current Audis. I will try to add a better pic later.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
mikesmith
post Dec 31 2013, 05:46 PM
Not really, no.
The old assembly is designed for a more or less point source (really a line) with relatively even light distribution around 360 degrees. The back half of that is then captured by the reflector and distributed forward towards the lens. By contrast, LEDs tend to have conical emission patterns, with most of the light flux close to the cone axis.
If you have a single LED (or a cluster of LEDs) in the same location as the old bulb, it will be sending most of its light directly forward towards a small portion of the lens, so the pattern will be weighted heavily towards whatever part was previously handled by the lens directly in front of the bulb. Even an LED with a wide pattern (120 degrees or so) is still only illuminating the lens from the point source, not from the reflector.
If all you want to do is present a glaring white dot to oncoming motorists, then that may be OK, but it's less effective visually than a larger illuminated area, and it certainly won't throw the same beam for the purposes of helping you see the road.
Take a look at the lenses on the JW Speaker or TruckLite LED headlights to get a feel for what purpose-designed LED optics look like. They're nothing like what you'd use with a filament bulb.
dangrouche   SMDs in the fog light housing   Dec 28 2013, 07:59 PM
Mike Bellis   :blink: Not sure how I feel about this. Hard to ...   Dec 29 2013, 01:53 AM
dangrouche   :blink: Not sure how I feel about this. Hard to...   Dec 29 2013, 11:25 AM
mikesmith   Holy DX ripoff, batman. Assuming they're the ...   Dec 29 2013, 02:10 AM
Porschef   Interesting. While you're in there, would you ...   Dec 29 2013, 08:01 AM
dangrouche   Interesting. While you're in there, would you...   Dec 29 2013, 11:29 PM
tscrihfield   The only concern I have is the styrofoam that they...   Dec 29 2013, 11:50 AM
euro911   Nice mod. I agree, you may want to mount them to ...   Dec 30 2013, 01:31 AM
dangrouche   Nice mod. I agree, you may want to mount them to...   Dec 31 2013, 12:15 PM
r_towle   post a link to these eagle eyes? I need to add so...   Dec 31 2013, 04:15 PM
dangrouche   post a link to these eagle eyes? I need to add s...   Dec 31 2013, 09:13 PM
Cap'n Krusty   Something seldom mentioned in discussions of HID a...   Dec 31 2013, 04:52 PM
euro911   So, would it be better to group a denser array mor...   Dec 31 2013, 05:05 PM
mikesmith   Not really, no. The old assembly is designed for ...   Dec 31 2013, 05:46 PM
dangrouche   I appreciate your comments. I don't think the...   Dec 31 2013, 09:24 PM
mikesmith   In case it wasn't clear, my point was that a ...   Jan 1 2014, 01:58 AM
dangrouche   In case it wasn't clear, my point was that a ...   Jan 1 2014, 10:22 AM
dangrouche   final iteration for DRLs, using the fog light hous...   Feb 1 2014, 08:35 PM
euro911   Hey, those look really cool. Who's the ebay se...   Feb 2 2014, 03:04 AM
Harpo   This looks to be the same thing http://www.ebay.c...   Feb 2 2014, 06:43 AM
dangrouche   This looks to be the same thing http://www.ebay....   Feb 16 2014, 02:22 AM
dangrouche   White 2x 90mm 24Led Bright SMD 5050 3Chip Car Led ...   Feb 2 2014, 05:30 PM
euro911   I wonder what would happen if you mounted them on ...   Feb 2 2014, 11:45 PM
dangrouche   great idea; give me a couple of weeks to do that o...   Feb 2 2014, 11:49 PM
- Lo-Fi Version Time is now: 21st December 2024 - 12:55 PM
