Fuel gauge still not working, What am I missing? |
john77 |
Mar 27 2014, 02:24 AM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
With the ignition on the needle on the gauge lifts to E but goes no further despite the tank being full.
I pulled the sender, wired up a new ground and hooked up a new wire from the gauge to the sender and tested the sender manually by turning it upside down and then back. The needle goes from empty to full and back to empty. Just to double check I test the resistance, 0.2 ohms right side up, 89.9 ohms upside down (the range is 0-90 ohms). So I put the sender back in the tank with the new wiring, switch on the ignition and... the needle rises to E and goes no further. So I think maybe, somehow, the floats not lifting. So I pull the sender, fill a bucket of water, dip it in, and the needle on the gauge rises and tells me I have half a tank - or less or more depending how much I submerge it. In other words, the damn thing is working. So I put it back in the tank and nothing, the gauge rises to E and stays!!! What the hell am I missing here? It works in a bucket of water but move it a foot and put it in my gas tank and nothing. John |
904svo |
Mar 27 2014, 12:42 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Guess a WAG but I supect the grond is missing off the gas gauge (brown wire) to
the gauge case. |
john77 |
Mar 27 2014, 06:52 PM
Guess a WAG but I supect the grond is missing off the gas gauge (brown wire) to the gauge case. Sorry, do you mean from the gas gauge ground terminal to the gas gauge case? So an internal wire? I've run a new wire from the gauge ground to a ground under the dash. A new wire to give power to the gauge. A new wire from the gauge to the sender. And a new ground from the sender to a ground. So all new wires. And the damn thing still won't rise above E with 4/5ths of a tank of gas! |
Lo-Fi Version | Time is now: 27th September 2024 - 03:21 PM |
