Fuel gauge still not working, What am I missing? |
john77 |
Mar 27 2014, 02:24 AM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
With the ignition on the needle on the gauge lifts to E but goes no further despite the tank being full.
I pulled the sender, wired up a new ground and hooked up a new wire from the gauge to the sender and tested the sender manually by turning it upside down and then back. The needle goes from empty to full and back to empty. Just to double check I test the resistance, 0.2 ohms right side up, 89.9 ohms upside down (the range is 0-90 ohms). So I put the sender back in the tank with the new wiring, switch on the ignition and... the needle rises to E and goes no further. So I think maybe, somehow, the floats not lifting. So I pull the sender, fill a bucket of water, dip it in, and the needle on the gauge rises and tells me I have half a tank - or less or more depending how much I submerge it. In other words, the damn thing is working. So I put it back in the tank and nothing, the gauge rises to E and stays!!! What the hell am I missing here? It works in a bucket of water but move it a foot and put it in my gas tank and nothing. John |
zambezi |
Mar 27 2014, 11:28 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
sounds like the sender is not grounding properly once mounted in the tank.
john77 |
Mar 28 2014, 12:53 AM
sounds like the sender is not grounding properly once mounted in the tank. I wondered if it had something to do with the metal shaft of the sender possibly touching the edge of the hole it sits in in the tank, so I asked a guy from the company and he said "The outside aluminum shell or shaft of our standard senders is grounded so touching the side will not hurt anything as long as the ground wire is on the correct lug or terminal.' So unless it's a problem internally with the sender I'm not sure what it could possibly be. Doesn't the fact it read 0-90 ohms when removed and inverted show the internals of the sender are fine though? |
Lo-Fi Version | Time is now: 27th September 2024 - 03:25 PM |
