Exterior Door handle Latch Cam, the plastic, piece that breaks. Question on replacement |
913B |
Apr 17 2014, 07:43 PM
Senior Member Group: Members Posts: 851 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
How do you replace them ?? I mean are you supposed to spread the two arms and pull the plastic out. I was afraid to break the arms by spreading them. Is the correct way to drill the rivet out and pull the pin, then get a shoulder allen bolt and nylon nut to re-assemble. ??
(IMG:style_emoticons/default/beerchug.gif) |
Valy |
Apr 17 2014, 08:23 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
How do you replace them ?? I mean are you supposed to spread the two arms and pull the plastic out. I was afraid to break the arms by spreading them. Is the correct way to drill the rivet out and pull the pin, then get a shoulder allen bolt and nylon nut to re-assemble. ?? (IMG:style_emoticons/default/beerchug.gif) No drilling! Just remove the old one and mount the new one instead. The replacement part has modification to ease installation. It's difficult to explain but pretty straight forward when you see the part. |
Lo-Fi Version | Time is now: 27th September 2024 - 02:16 PM |
