GB- Front trunk cable with plastic guide, $22 + shipipng for both |
Mikey914 |
May 29 2014, 11:32 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is for the front trunk cable along with the guide tube. I found that mine was cracked and didn't allow the cable to pull effectively, so here you go. These will be ready next week.
Once again, who needs em? (IMG:style_emoticons/default/type.gif) Attached thumbnail(s) |
jim_hoyland |
May 29 2014, 07:24 PM
Get that VIN ? Group: Members Posts: 9,418 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
That' same nice item (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) what is the length of the wire ? Reason I ask is the last one I bought from XXXXX, it was an inch or so sort. I had to cut the inner corner to make it reach....looked bad
Mikey914 |
May 29 2014, 11:14 PM
That' same nice item (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) what is the length of the wire ? Reason I ask is the last one I bought from XXXXX, it was an inch or so sort. I had to cut the inner corner to make it reach....looked bad No fear Jim, Mine will be longer than required, You will have to cut it, not your car. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 11:30 AM |
