steering wheel wobble, sleeve or bearing |
malcolm2 |
Jun 4 2014, 01:06 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I installed my new Meyle key switch last night and that reminded me that I have a steering wheel wobble. The play is up and down, not side to side. check out the video.
Should I buy a sleeve or a bearing for my 75? maybe both? BTW the new German made $8 switch fires the car right up. (IMG:style_emoticons/default/driving-girl.gif) It fit very tightly so I assume it will last. The one I took out had "GERMANY" on it. Not sure if it is from the PO or the factory. https://www.youtube.com/watch?v=oD4V040AZQE |
messix |
Jun 4 2014, 06:00 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
the column where the bearing is can get wobbled out from hanging on to the wheel getting in and out so the bearing fits loose. I used some aluminum foil to shim the bearing in tight.
Dr Evil |
Jun 4 2014, 06:34 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
the column where the bearing is can get wobbled out from hanging on to the wheel getting in and out so the bearing fits loose. I used some aluminum foil to shim the bearing in tight. Yup. That is the next culprit. See, if the bearing were loose then the shaft of the wheel would move in all directions. So, a bushing will not fix up and down only. Depending on how bad the collar is worn out, foil can help, and make sure it is a tight fit or you will be right back there messing with it again. Last time I messed with this problem I documented it and posted the pics up. I also gave up and went with another collar. |
Lo-Fi Version | Time is now: 27th September 2024 - 05:51 AM |
