oil filter flange gasket, and oil pump |
jacksun |
Jun 28 2014, 01:27 PM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
hi,
my question is regarding the oil filter flange and where I might purchase the gasket between the flange and the case? also. the oil pump in the image was covered in oil... does this mean that the pump seals need replaced? or is it oil coming from the oil cooler gasket or also from the push rod seals or the valve cover gasket... or all three.. there was no oil on the top of the engine bar between the motor mounts. any thoughts are appreciated. thanks randal |
stugray |
Jun 28 2014, 03:03 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Use permatex 515. Sorry - Loctite-518
It's translucent red. You wont need the gaskets. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:35 AM |
