Help me win at autocross, I wanna be a top 10 car and driver! |
crash914 |
Jul 1 2014, 06:49 PM
its a mystery to me Group: Members Posts: 1,827 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
ok, I need help. currently I am about 3 to 5 seconds off the pace in my local club events. I know most of the time is due to the driver. I think that there is some time in the car also as it is mostly set up for the long track.
Here is what I know so far, if more info is needed..ask... 73 914, blue. bolt in cage, just the 4 plates plus the seat belt for tie in points. stiffly sprung, Koni yellows, I think 250 lbs in the rear and 21 or 23mm torsion bars in the front. Delrin bushings everywhere, I have needle bearings, just not installed. lowered, see pictures for height. 4 inches in the rear to the bottom of the engine mount bar, 4 inches in front to the bottom of the front floor pan. 205 50 15 tires, not sure of the wheel width, 4 lug. my tires are about 8 year old khumo v710's that have been in the garage and have 4 autocross days on them now. air pressure I have been running, 22lbs front, 20 rear. see pictures for chalk. looks like I am using all the tread. Camber is close to -2.4 degrees front and rear. Front toe is 0, not sure about the rear, perhaps 1/4 inch toe in. Motor is 103 by 80, nickies, split cam, le200 heads, tangerine header, 6800 rpm redline, 11:1 compression, so plenty of grunt. Megasquirt with twin throttle bodies. Transmission is open diff, with a flipped 5th gear for 3rd and standard 5th. no camber plates, See pictures in the following posts.. |
Joe Ricard |
Aug 10 2014, 07:02 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
as mentioned above and demonstrated in several videos. DRIVER DRIVER DRIVER.
Lo-Fi Version | Time is now: 27th September 2024 - 07:51 AM |
