Bushings for shift rod coupling, How to install |
jack20 |
Nov 21 2014, 09:14 AM
Member Group: Members Posts: 412 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Ordered all new shift linkage bushings. The bushings for the coupling near firewall have me stumped. Does the rod need to be pressed out to install the bushings? Or...do I remove the old bushing and slip the new ones in from the outside?
stugray |
Nov 21 2014, 09:36 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The rod has to come out.
If it is a tail shift, I believe the rod can be pulled out the rear. If it is a side shift, the bar cannot be removed completely with the engine bar in the way. FOr that disconnect the bar on both ends and push it forward into the tunnel while you replace the bushing. Some have luck heating the bushing in bioling water and popping it in. That didnt work for me for whhatever reason so I used a carriage bolt and some large washers and sandwiched the bushing in place. That way you just tighten a nut and it pushed the bushing right in. |
jack20 |
Nov 21 2014, 09:41 AM
The rod has to come out. If it is a tail shift, I believe the rod can be pulled out the rear. If it is a side shift, the bar cannot be removed completely with the engine bar in the way. FOr that disconnect the bar on both ends and push it forward into the tunnel while you replace the bushing. Some have luck heating the bushing in bioling water and popping it in. That didnt work for me for whhatever reason so I used a carriage bolt and some large washers and sandwiched the bushing in place. That way you just tighten a nut and it pushed the bushing right in. Thanks for the reply. The shift rod is out of the car. I am referring to the bushings in the coupling, looks like a U joint. Does the pin holding the coupling together need to be pressed out to install the 2 bushings in the coupling? |
Lo-Fi Version | Time is now: 27th September 2024 - 06:44 AM |
