Rear Brake Lockup Help, Help |
spaceshuttle |
Nov 15 2014, 10:42 AM
Member Group: Members Posts: 73 Joined: 25-November 06 From: SouthCarolina Member No.: 7,258 |
I am running larger 4 piston Outlaw (read Willwood) calipers on the front of my v6 track car, with 911 M calipers on the rear. I installed a brake bias adjuster knob initially but my rears lockup under heavy braking no matter the adjustment. Switched to a Tilton bias adjustment with the notched rod with multiple positions and still no change. I cannot tell that there is much difference in the pressure to the rears. They will lockup no matter the position under heavy braking. They are not sticking. Not sure which direction to go from here. I am running Hawk blues front and rear. Perhaps a less aggressive rear pad? And yes the factory proportioning valve was removed.
thanks for any help guys. LC |
jd74914 |
Nov 28 2014, 09:58 PM
Its alive Group: Members Posts: 4,796 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Before doing anything I would corner balance with you in the car. My formula car experience has been that corner weights have a huge effect on things like this. Messed up corner weights can do really wacky things...
Randal |
Nov 28 2014, 10:52 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Before doing anything I would corner balance with you in the car. My formula car experience has been that corner weights have a huge effect on things like this. Messed up corner weights can do really wacky things... Big secret here. Use the weight balance to determine tire widths. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:15 AM |
