New GB late airbox grill and new Gasket,, $34 for Both --- Add the airbox rebuild kit for $14 Who's in? |
Mikey914 |
Dec 10 2014, 08:57 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We just finished the mold for the grills on the late air box and they look just like factory (less the over spray). The grills have been harder to find in good condition but now you can get one NEW!
No new grill would be complete without a new seal to hold it into place. We didn't just phone this one in. Other seals use an extruded strip of rubber and notch the corners to make a rectangle to hold the grill and slide over the top of the air box. We molded a seal to fit the air box perfectly. We also made it out of silicone to make a good seal. Not just a fin or flap, but a little over 1/4" flat seal all the way around. The real beauty of this seal is that when it is installed it will actually force the grill to sit about 1/16" below the body grill. These will be about $25 each for the seal and the same for the grill after the GB is over. It's also a good time to re seal the flapper valved in the air box, so if you want to add that in, it has been discounted to make this project more complete. Attached thumbnail(s) Attached image(s) |
warrenoliver |
Dec 11 2014, 04:49 PM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
My '73 does not have a grill (I assume this is fitted under the cowl). I did not know one was available but it certainly needs one to keep the crap out of the airbox and to keep it from eventually blowing leaves and other junk into the car.
Do I have to remove the airbox in order to install this? Any pics of a car with this installed? |
Lo-Fi Version | Time is now: 27th September 2024 - 07:44 AM |
