Car has spark! My suby setup, Now just dbl checking all wires to be sure load are good before running |
JRust |
Dec 21 2014, 12:00 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so my wrench called last night. Car was all finished & he went to fire it up. Turns over fine but no start. This is what it was doing before the fire. Also off & on it has plagued me since I got the car. I've replaced the ignition with multiple times. I added a push button for the starter to take that off the switch. Seemed like there was to much power going through it which I thought was from the starter. Obviously it is not.
One thing is almost without fail as soon as I put in a new switch & use it I get smoke from it every time. It would be fine right after the brief smoke so I didnt worry to much about it. What else is feeding the ignition switch that may be pushing to much power through it? What do you guys recommend doing here? Cutting out the switch completely? Do you think the problem lies somewhere besides the switch? |
904svo |
Jan 16 2015, 07:25 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
On my conversion I took the ign wire ( power lead to the coil) and wired it up to
new power relays to feed the ECU, fuel pump power which takes the load off the ign switch. I also added a power relay to the starter circuit. These changes will remove the large current drain which the ECU,fuel pump require from the ign switch. |
76-914 |
Jan 17 2015, 10:44 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
On my conversion I took the ign wire ( power lead to the coil) and wired it up to new power relays to feed the ECU, fuel pump power which takes the load off the ign switch. I also added a power relay to the starter circuit. These changes will remove the large current drain which the ECU,fuel pump require from the ign switch. Same here. I believe "that power lead" is #9 blk. In fact, you, Mike B., Tom, Spoke (who is cheaper than I (IMG:style_emoticons/default/lol-2.gif) ) and a few others, "held my hand" as I wired mine up. Can't thank you guy's enough for your experienced views and tips. Also, you can't have too many relays or grounds on the 914's meager wiring system. Did Dean install the "power relay" from the original Suby wiring system? |
Lo-Fi Version | Time is now: 27th September 2024 - 04:54 AM |
