engine options, 914 engine mods |
HaraPuzo |
Jan 21 2015, 12:50 PM
Newbie Group: Members Posts: 37 Joined: 4-December 14 From: Canada Member No.: 18,187 Region Association: Canada |
Hi, I'm curious to know about engine options to build a "six". I've seen other 911 engines and subaru engines too. but has anyone tried Honda/Acura? Maybe a motorcycle engine build? I'm no mechanic. not sure if this is even possible.
any advice is welcome (IMG:style_emoticons/default/smile.gif) Thank you! |
SirAndy |
Jan 21 2015, 01:27 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
IMHO, smaller 911 engines (up to 3.2L) are by far the easiest to install since they are a direct bolt in and the 914 chassis was built to accommodate them.
(IMG:style_emoticons/default/shades.gif) |
Dave_Darling |
Jan 21 2015, 01:54 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
IMHO, smaller 911 engines (up to 3.2L) are by far the easiest to install since they are a direct bolt in.... Not exactly bolt-in... The welded-in mounts are definitely preferred, and of course you have to do some cutting of the side of the engine bay to fit the oil tank... But the 911 engines are a very well-understood swap, and improve the car markedly. No debates about them, like there are about the V8 and Scooby motor swaps. --DD |
SirAndy |
Jan 21 2015, 03:48 PM
Not exactly bolt-in... The welded-in mounts are definitely preferred, and of course you have to do some cutting of the side of the engine bay to fit the oil tank... For the smaller displacements, a quick six mounting bar using the stock /4 engine mounts is sufficient and the factory already stamped the sheetmetal where one needs to cut holes for the oiltank. So yes, i stand by my earlier post. Bolt-in with minimum amount of work. (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 09:07 PM |
