Exhaust stud woes, What's the next step? |
saigon71 |
Jan 24 2015, 11:39 AM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Nothing is ever easy on these cars...
My heat exhangers got some oil in them from the bad oil cooler seals, so I decided to pull them for a good cleaning. One exhaust nut was really difficult to remove. Once I finally got it off, I saw that the threads were galled. Ordered some new exhaust studs. Went to work removing the old one after researching 914 world. Heated stud boss with MAP torch & sprayed a bunch of PB blaster. Welded a nut on the end...nut kept breaking loose without budging the stud, removing small portions off the top of the stud during the six attempts. Then welded a bar to the remainder of the stud and used an adjustable wrench for leverage. Heat & PB Blaster, working it a little at a time, back & forth. It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head. Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud? I've had horrible luck with EZ-outs on other applications. Thanks! |
pilothyer |
Jan 24 2015, 11:49 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I know this is not what you want to hear, but since the removal of the muffler and heat exchangers is about the worse part of engine removal (although not necessary) I think your best bet would be to drop the engine/transaxle remove the head and take it to a machine shop for the extraction. This will cost extra if an easy out is broken off in the stud.......I feel your pain because I have BTDT,
Lo-Fi Version | Time is now: 23rd November 2024 - 01:37 AM |
