Exhaust stud woes, What's the next step? |
saigon71 |
Jan 24 2015, 11:39 AM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Nothing is ever easy on these cars...
My heat exhangers got some oil in them from the bad oil cooler seals, so I decided to pull them for a good cleaning. One exhaust nut was really difficult to remove. Once I finally got it off, I saw that the threads were galled. Ordered some new exhaust studs. Went to work removing the old one after researching 914 world. Heated stud boss with MAP torch & sprayed a bunch of PB blaster. Welded a nut on the end...nut kept breaking loose without budging the stud, removing small portions off the top of the stud during the six attempts. Then welded a bar to the remainder of the stud and used an adjustable wrench for leverage. Heat & PB Blaster, working it a little at a time, back & forth. It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head. Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud? I've had horrible luck with EZ-outs on other applications. Thanks! |
JamesM |
Jan 26 2015, 04:58 PM
Senior Member Group: Members Posts: 1,991 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Pull the engine now, it will save you in the long run.
You may get lucky drilling/extracting with the motor in the car, but it is a PITA and you will most likely just make the situation worse resulting in more costly repairs and requiring you pull the motor anyways. |
larryM |
Jan 27 2015, 10:35 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
X2
assuming you have plenty of money, & can let the car be dead for some months pull the heads & send 'em to FAT or some other Type 4 expert for complete rebuilds - we already gave you other alternatives Pull the engine now, it will save you in the long run. You may get lucky drilling/extracting with the motor in the car, but it is a PITA and you will most likely just make the situation worse resulting in more costly repairs and requiring you pull the motor anyways. |
Lo-Fi Version | Time is now: 23rd November 2024 - 01:54 AM |
