> Exhaust stud woes, What's the next step?
saigon71
post Jan 24 2015, 11:39 AM
Nothing is ever easy on these cars...
My heat exhangers got some oil in them from the bad oil cooler seals, so I decided to pull them for a good cleaning. One exhaust nut was really difficult to remove. Once I finally got it off, I saw that the threads were galled.
Ordered some new exhaust studs.
Went to work removing the old one after researching 914 world.
Heated stud boss with MAP torch & sprayed a bunch of PB blaster.
Welded a nut on the end...nut kept breaking loose without budging the stud, removing small portions off the top of the stud during the six attempts.
Then welded a bar to the remainder of the stud and used an adjustable wrench for leverage. Heat & PB Blaster, working it a little at a time, back & forth. It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head.
Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud?
I've had horrible luck with EZ-outs on other applications.
Thanks!
Cap'n Krusty
post Jan 31 2015, 07:03 PM
Cap'n Krusty
"New" exhaust nuts? Good luck finding those. I may have one or two used ones left; I keep finding them as we go through the stuff in the barn. They're Helicoiled on the inside, and should be fine for reuse. ALL the replacement nuts sold by almost everyone are of the locking variety, which were NEVER intended for use in this application.
The Cap'n
Bartlett 914
post Feb 1 2015, 12:21 PM
QUOTE(Cap'n Krusty @ Jan 31 2015, 08:03 PM) *
The Cap'n
Would you mind showing a pic of the proper nuts? May these can be produced. What about SS nuts
stugray
post Feb 1 2015, 01:49 PM
QUOTE(Bartlett 914 @ Feb 1 2015, 11:21 AM) *
Last time I installed mine I used 8mm "Jis Nuts" from Ace Hardware.
They have a smaller OD so that you can use a smaller socket.
My aftermarket headers dont fit as nice as the stock, so I needed the extra room.
Once I torqued them to spec, I double nutted them.
Oh! ANd excellent job on drilling the stud out.
You clearly DO have the patience and forethought to do it right.
You should keep that drill guide kit handy and offer it to others as this happens to them.
saigon71   Exhaust stud woes   Jan 24 2015, 11:39 AM
pilothyer   I know this is not what you want to hear, but sinc...   Jan 24 2015, 11:49 AM
Mark Henry   Really hard to do in car. What you did there is s...   Jan 24 2015, 12:03 PM
veekry9   Nothing is ever easy on these cars... ....It fin...   Jan 24 2015, 01:25 PM
larryM   . your question updated you should be able to get...   Jan 25 2015, 01:22 PM
stugray   It can be done as mentioned above, but if you are ...   Jan 25 2015, 11:13 PM
JamesM   Pull the engine now, it will save you in the long ...   Jan 26 2015, 04:58 PM
larryM   X2 assuming you have plenty of money, & can ...   Jan 27 2015, 10:35 PM
Mueller   I botched an attempt at drilling out an exhaust st...   Jan 28 2015, 09:20 AM
9146986   You'll get closer to hitting the center of the...   Jan 28 2015, 09:37 PM
relentless   The stud is broken off below the level of the head...   Jan 29 2015, 04:05 PM
9146986   I didn't mean to sound insulting Saigon, I jus...   Jan 29 2015, 09:48 PM
stugray   A vintage piece of equipment that really works go...   Jan 30 2015, 12:05 AM
saigon71   Thanks for all the advice and suggestions – I gr...   Jan 31 2015, 05:06 PM
saigon71   Made three different fixtures so I could step dril...   Jan 31 2015, 05:31 PM
type47   Go Bob, go! :trophy:   Jan 31 2015, 05:40 PM
saigon71   I am very happy to report that it worked well. Us...   Jan 31 2015, 05:47 PM
mepstein   Wow! You knocked it out of the park. Congrats...   Jan 31 2015, 05:54 PM
saigon71   Glad to have this project done! I’m going t...   Jan 31 2015, 05:59 PM
Cap'n Krusty   "New" exhaust nuts? Good luck finding t...   Jan 31 2015, 07:03 PM
mepstein   "New" exhaust nuts? Good luck finding ...   Jan 31 2015, 07:11 PM
Bartlett 914   "New" exhaust nuts? Good luck finding ...   Feb 1 2015, 12:21 PM
stugray   Would you mind showing a pic of the proper nuts? ...   Feb 1 2015, 01:49 PM
914Mike   I've used brass nuts, never had one get stuck ...   Jan 31 2015, 11:22 PM
relentless   Nice job! I picked up some 8mm copper exhaust...   Feb 1 2015, 01:57 PM
pilothyer   These should work Helicoil Flange Nuts   Feb 1 2015, 02:26 PM
Harpo   These should work Helicoil Flange Nuts This sup...   Oct 1 2015, 06:15 PM
ClayPerrine   I use a Mercedes Benz exhaust manifold nut. Merce...   Feb 1 2015, 06:25 PM
ThePaintedMan   This is one of the most well-thought out and brigh...   Feb 2 2015, 08:00 AM
mepstein   Stomski makes a tool in a kit with all different a...   Oct 1 2015, 04:06 PM
saigon71   Stomski makes a tool in a kit with all different ...   Oct 3 2015, 04:17 PM
wndsnd   I am impressed. It sucks working on your back wit...   Oct 1 2015, 07:39 PM
porsche913b_sp   Dang you the MAN, I like your persistence and not ...   Oct 2 2015, 02:43 PM
saigon71   Dang you the MAN, I like your persistence and not...   Oct 3 2015, 04:22 PM
mepstein   I would think so since there are many different si...   Oct 3 2015, 04:25 PM
ctc911ctc   I started replacing all of my studs with the engin...   Apr 7 2020, 12:26 PM
Bleyseng   I started replacing all of my studs with the engi...   Apr 7 2020, 03:42 PM
- Lo-Fi Version Time is now: 23rd November 2024 - 01:21 AM
