Speedo Repair? |
Speedo Repair? |
Last930 |
Oct 14 2014, 08:20 AM
Member Group: Members Posts: 60 Joined: 15-September 14 From: Illinois Member No.: 17,905 Region Association: Upper MidWest |
The spedometer works on the '73 914 I am acquiring, but the odometer does not; neither does the trip meter. I assume this means something has broken inside the speedo? Any suggestions as to the best place to send it for repair?
Dave_Darling |
Mar 8 2015, 03:47 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Usually there's no new gear needed. The typical failure mode is that a pot-metal gear inside the odo mechanism starts to spin on its shaft, rather than turning with the shaft. Simply peen the area around the hole in the gear to distort it, and put the shaft back through the hole. Or use some epoxy, perhaps?
--DD |
Lo-Fi Version | Time is now: 27th September 2024 - 01:18 AM |
