01e vs boxster s, bellhousing bolt pattern same ? |
got914? |
Apr 5 2015, 07:10 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Ive been searching and cant seem to find the answer.
I know someone on here has the answer. Are the Audi 01E and boxster s the same bellhousing bolt pattern ? |
got914? |
Apr 6 2015, 12:23 PM
Ok sounds good.
Something else i read on another forum ( not sure if i bookmarked it or not) Is there any truth to the following ? Spline for clutch input shaft has different spline count and 1 mm differnet size ) easy enough to solve) And that the input shaft is 25 MM shorter ?, would this still engage with a KEP setup does anyone know ? |
Mueller |
Apr 6 2015, 12:37 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Ok sounds good. Something else i read on another forum ( not sure if i bookmarked it or not) Is there any truth to the following ? Spline for clutch input shaft has different spline count and 1 mm differnet size ) easy enough to solve) And that the input shaft is 25 MM shorter ?, would this still engage with a KEP setup does anyone know ? KEP would know all of that if they make and adapter and flywheel. If different and if they make the adapters/flywheels for each version you'd get what you need. Perhaps call them, they should be open right now... |
Lo-Fi Version | Time is now: 27th September 2024 - 01:19 PM |
