01e vs boxster s, bellhousing bolt pattern same ? |
got914? |
Apr 5 2015, 07:10 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Ive been searching and cant seem to find the answer.
I know someone on here has the answer. Are the Audi 01E and boxster s the same bellhousing bolt pattern ? |
got914? |
Apr 6 2015, 09:07 PM
I never measured an 01E but the Boxster 5 & 6 speed is the same 36 spline shaft length as the Audi/VW 012 transmission. I have swapped my Passat 5 speed with my Boxster S 6 speed a couple times. I use the VW 225mm clutch & flywheel. This makes me feel good QUOTE The 01E input shaft is 24mm (15/16") Dia. x 23 spline. Andys Yes i found the porsche is 1 inch by 23 spline, so just for argument sakes run a porsche pressure plate and an audi disc. Or deal with the 1/16 inch diff which is only 1/32 side to side play. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:24 PM |
