Transaxle issue?, Feels like I'm running over speed bumps |
rtalich |
Apr 17 2015, 10:18 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Issue just started last night. Just starting out in first gear while slipping the clutch. Once clutch engages at lower RPMs it felt like I was rolling over speed bumps. At faster speeds it seemed fine. Now it is starting to happen more frequent but only at lower RPMs. I have not had a chance to diagnose yet. Anything in particular come to mind?
Thanks Rob |
McMark |
Apr 17 2015, 01:40 PM
Also could be a slipping clutch. Also, you could drain the transmission into a clean container. Check for chunks. If it's fine, just pump it back in.
messix |
Apr 19 2015, 12:44 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
Also could be a slipping clutch. Also, you could drain the transmission into a clean container. Check for chunks. If it's fine, just pump it back in. when did our trannys start being a wet clutch set up? (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 06:33 AM |
