2056 Build, Just starting teardown; some questions |
Spoke |
May 31 2015, 06:55 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Finally getting into building a 2056 for my 914. Plan is to rebuild one of the two 2L engines I have with 96mm AA P/Cs. For induction, I have D-Jet from one of the 2L engines with a good MPS and set of Weber IDF40s. I would like to stay with FI but will consider using the Webers.
The engine will have ceramic coated SSHE along with a Bursch muffler. The first engine I bought was advertised as a 2L core with FI. In reality the engine was "cored". There is a hole about 3/8 x 1/2 inch in the case. Looks like the engine was run even with the hole as there is a good amount of dirt+oil on the fins of cylinders 3&4. Also one of the spark plug threads is stripped on cylinder #4. The seller said he would give me a line bored case that he has but I've yet to see it. I bought the engine in Aug of last year so I'm losing hope of getting the case; This ranks up there with one of my worst purchases. Since the first engine's case was trashed and the seller hasn't come through with the promised replacement case, I purchased a 2nd engine from Brad Mayeur that had been running. This one came with the Webers and likely will be the basis of my engine. |
Spoke |
Jul 11 2015, 07:19 PM
Time for a little detour...
So now I have 2 good cases; internals from 2 engines; one with 96mm pistons; A set of weber dual carbs; a complete D-JET setup including an MPS which holds vacuum. The detour is I will leave the P/C on the 2nd engine; clean it up; reassemble and see if/how it runs with the carbs. If this engine runs well, I'll dump it in my 914 and use the cleaned case and other internals to take my time and build a 2056 DJET engine. Here's the current state of the 2nd engine. Degreased the case, cylinders and heads. Reinstalled the heads with new sealing rings. Reinstalled pushrods and pushrod tubes with new o-rings, and adjusted the valves. Next up is to clean the bottom of the engine, put the oil temp sender from the first engine on this one, put it back together with the carbs and fire it up. If it runs ok I'll put it in the car and work on the other engine at my leisure. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:10 AM |
