76 subaru conversion |
carphappy |
Sep 9 2015, 06:29 AM
Newbie Group: Members Posts: 13 Joined: 6-September 15 From: hudson valley, ny Member No.: 19,132 Region Association: North East States |
hi everyone. several years ago i built myself a jdm ej20k subaru powered 914. unfortunately i did not document my progress. because it already had an aftermarket body kit installed i had no ethical reasons not to install a different motor. i am using a diy megasquirt ecu with the stock cam and crank sensors to control the motor. to say that i learned a thing or two along the way would be an understatement. thanks to everyone who has done a subaru conversion before me. your posts have inspired me and helped in numerous decision making situations. here are a couple of pics.
Chris H. |
Sep 9 2015, 09:40 AM
Senior Member Group: Members Posts: 4,043 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
So are you using that stock temp gauge ? The combo gauge to the left of the tach? Oil temp or water temp?
carphappy |
Sep 9 2015, 10:55 AM
So are you using that stock temp gauge ? The combo gauge to the left of the tach? Oil temp or water temp? i am using the stock temp gauge as an oil temp gauge. i installed an electric sending unit in the oil pan and hooked it up to the existing wire. on hot days it moves beyond vertical but it has never reached the red zone. i am thinking that it is relatively accurate. i made the center console, it holds the oil pressure, water temp, boost, and afr gauges. |
TheBabyBadger |
Sep 9 2015, 11:56 AM
Newbie Group: Members Posts: 8 Joined: 25-August 15 From: Fairfield, CA Member No.: 19,103 Region Association: Northern California |
So are you using that stock temp gauge ? The combo gauge to the left of the tach? Oil temp or water temp? i am using the stock temp gauge as an oil temp gauge. i installed an electric sending unit in the oil pan and hooked it up to the existing wire. on hot days it moves beyond vertical but it has never reached the red zone. i am thinking that it is relatively accurate. i made the center console, it holds the oil pressure, water temp, boost, and afr gauges. Awesome build! Love the set up. Venting through the floor? Wheel wells? Would love to see more pics. I run the same kit on my car. |
Lo-Fi Version | Time is now: 27th September 2024 - 07:49 AM |
