> Mini V8 Thread, Installing my old v8 in a members 914
Andyrew
post Oct 20 2015, 08:19 AM
Spooling.... Please wait
There will be a lack of progress on my car until I get this members 914 running with my v8 setup. The only requirement is that the engine will start, run, and move the car.
Below is my list of work to do.
Pull Fuel Tank
Replace stock fuel lines
Plumb fuel pump
Replace firewall shift bushing
Cut holes for radiator lines in front trunk
Mount radiator lines
Cut notch for HEI Dizzy
Clearance valve cover
Bolt up engine/trans
Bolt up cv joints
Install shoft linkage and adjust
Install distributor and carb
Install clutch, throttle and speedo cables
Wire starter, dizzy, alternator
Test fire
Flush coolant
Bleed brakes
Drive
Total hours involved is anticipated at 26 by myself. I origially agreed that the owner would have the car 100% ready for the swap and I would only have to do the v8 portion, (which I have a anticipated at 20.5hrs) however the fuel line issue, firewall shift bushing, and bleeding the brakes are all going to be done on a T&M basis.
Overall its a good looking body with a few dents and paint that shows its age. There is a bit of rust in the firewall and battery tray and some in the pass front door jamb, but the rear suspension console looks great. I think its a great candidate for a conversion.
Andyrew   Mini V8 Thread   Oct 20 2015, 08:19 AM
rhodyguy   That yellow will be a sleeper for sure.   Oct 20 2015, 08:22 AM
Andyrew   Progress from last night. Ready for installing t...   Oct 20 2015, 08:23 AM
JmuRiz   Off topic: But what's with the oil coolers on ...   Oct 20 2015, 08:35 AM
76-914   :popcorn: Were the OE plastic lines still good? M...   Oct 20 2015, 08:35 AM
Andyrew   Plastic lines looked good. Fabric lines were ready...   Oct 20 2015, 08:47 AM
Mueller   Slightly disappointed in thread title :( I was ho...   Oct 20 2015, 09:36 AM
matthepcat   Slightly disappointed in thread title :( I was h...   Oct 20 2015, 02:13 PM
Andyrew   [quote name='Mueller' post='2254545' date='Oct 20...   Oct 20 2015, 05:38 PM
Andyrew   San Jose local, yes. Member also has a 6 conversio...   Oct 20 2015, 10:02 AM
screenguy914   Not sure how fast you work or your personal level ...   Oct 20 2015, 02:56 PM
jimkelly   he is one lucky guy :shades2: and will be one ha...   Oct 20 2015, 05:23 PM
whitetwinturbo   :popcorn: :popcorn: :popcorn:   Oct 20 2015, 10:58 PM
Mike Bellis   You crazy! :screwy:   Oct 20 2015, 11:16 PM
Andyrew   Progress from tonight, Fuel lines in ...   Oct 20 2015, 11:53 PM
jimkelly   on my V8 car i cut that hole below the fuel lines ...   Oct 21 2015, 06:49 AM
Andyrew   I will likely take the typical route of making the...   Oct 21 2015, 08:46 AM
bigkensteele   I will likely take the typical route of making th...   Oct 26 2015, 05:44 PM
Andyrew   Firewall rust :( The owner and I are discuss...   Oct 22 2015, 11:43 AM
Andyrew   More..   Oct 22 2015, 11:48 AM
Andyrew   A bit more digging of the rust. As I anticipated i...   Oct 23 2015, 06:38 PM
matthepcat   Yikes. The owner might want to delay engine instal...   Oct 23 2015, 09:52 PM
Andyrew   The owner has agreed to have me repair the rust. I...   Oct 23 2015, 10:05 PM
Andyrew   Got the easy ones out of the way this evening.... ...   Oct 24 2015, 02:44 AM
RobW   Nice work. Full service. :headbanger:   Oct 24 2015, 05:14 AM
Andyrew   Progress from yesterday morning. Had a concert to ...   Oct 25 2015, 09:37 AM
whitetwinturbo   What is the gooey stuff on the weld line :confuse...   Oct 25 2015, 09:53 AM
Andyrew   What is the gooey stuff on the weld line :confus...   Oct 25 2015, 10:04 AM
whitetwinturbo   What is the gooey stuff on the weld line :confu...   Oct 27 2015, 06:40 PM
Andyrew   Drivers side done :) Now onto the pas...   Oct 25 2015, 07:10 PM
Andyrew   The answer was leave the hole and rip the battery ...   Oct 25 2015, 11:36 PM
76-914   :popcorn:   Oct 26 2015, 10:57 AM
Andyrew   Fought a cold ALL week so I didnt make any progres...   Oct 31 2015, 07:35 PM
Andyrew   Installed new water and alternator belts. Remove...   Nov 2 2015, 12:39 AM
Andyrew   Made some progress a bit last week and on Saturday...   Nov 9 2015, 02:15 PM
bfrymire   I will look for the mounts and I have the rear hoo...   Nov 2 2015, 01:56 AM
Chris Pincetich   :trophy: :beer2:   Nov 3 2015, 10:28 AM
Andyrew   Everything is in! As per normal v8 conversi...   Nov 14 2015, 09:50 PM
JRust   Nice Andrew! That will be a kick for the owner...   Nov 14 2015, 11:04 PM
arkitect   Andrew, Nice looking work...looks like a shop did ...   Nov 15 2015, 08:01 AM
Andyrew   Jamie, I agree. This engine runs heaaaalthy... got...   Nov 15 2015, 12:15 PM
Andyrew   Quick test fire wjAddAmtpRc   Nov 15 2015, 12:28 PM
Mueller   Quick test fire wjAddAmtpRc Sounds great...wha...   Nov 15 2015, 12:35 PM
whitetwinturbo   :headbanger: :cheer: :headbanger: :cheer: :hea...   Nov 15 2015, 01:02 PM
mgp4591   IT'S ALIVE!!! :headbanger:   Nov 15 2015, 04:36 PM
arkitect   Andrew, You are a master metal man, what you spent...   Nov 15 2015, 08:14 PM
Andyrew   Thats why I charge the big bucks :)   Nov 15 2015, 09:48 PM
bfrymire   Thanks Andrew and great work!   Nov 16 2015, 12:45 AM
Justinp71   Nice Work!   Nov 16 2015, 02:51 PM
- Lo-Fi Version Time is now: 23rd November 2024 - 04:28 AM
