Tie-rod end question |
SKL1 |
Nov 19 2015, 09:49 PM
Senior Member Group: Members Posts: 1,625 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Was bleeding brakes today and tightening connections on the front sway bars and checked tightness of nuts on tie rod ends.
Pass side nice and tight. On driver's side the nut and shaft would spin rather easily but did turn together. Everything seems tight and no noticeable slop when driving. Also noted no way to put in cotter pins- couldn't find any holes. Can't figure out why one side is tight and other side turns?? Sorry for "dumb" question!! Ball joints are new on both sides... Wondered about new tie rod ends from Pelican- figured I'll need the tool to push out the old ones, right?? |
dangrouche |
Nov 19 2015, 11:00 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
The tie rod ends I have removed have always needed a ball joint separator or pickle fork. The Lemforder OEM tie rod ends used cotter pins. the non-OEM cheaper ones (made in Asia) use a Nyloc nut. The one that that you have that is rotating may either be not snugged up enough or there may have been a bit of grease in the hole when it was installed and that accounts for the ability for it to rotate. but if you say there is no slop, I would double check that you have no play whatsoever. could be that tie rod end was not up to spec. If you needed a wrench to rotate that nut, then I would not worry about it. If I can turn the nut with my hand, then I would replace that tie rod end. thinking about it some more, that steering arm may have an enlarged bore which accounts for you ability to rotate that tie rod end.
Lo-Fi Version | Time is now: 27th September 2024 - 01:58 PM |
