Flywheel needle bearing placement, Exact depth of needle bearing location |
pgollender |
Mar 5 2016, 09:47 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
1970 914 1.7 L:
When replacing the Flywheel needle rolling bearing what is the preferred depth ? There is a felt washer that gets sandwiched between the race of the needle bearing and the locking washer. Should the race be flush with the out side of the flywheel so the felt washer gets smashed or do you recess the race 1-2 mm in to accommodate the washer so it doesn't get distorted ?. Also the needle bearing two race surfaces are slightly different. One side is "fatter" the other side is more narrow. Does the race direction matter ? |
pgollender |
Mar 5 2016, 11:46 AM
Thanks Mat: Any input about the race surface direction ?
Here is the other side of the race currently pressed on the inside of the flywheel. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:57 PM |
