Lots of 914 Doo-dads, Transmission, Radio, Engine Tin, etc., MAKE AN OFFER ON ANYTHING!!! |
Mathman |
Mar 16 2016, 11:45 AM
Newbie Group: Members Posts: 25 Joined: 10-May 14 From: Kansas Member No.: 17,330 Region Association: None |
Hi, all! I'm downsizing my 914 hoard, and I was curious if anyone had any need for this stuff before it goes away. I hate to toss it if someone needs it, so PLEASE make an offer. I promise that I won't be offended. I only list the prices because we're supposed to. Please note that all electrics are untested and all items are understood to be driver quality. The transmission was good when it was removed. If you have any questions, please shoot me a PM/E-mail/reply. I'll reply as soon as I am able. Payment via PayPal, shipping extra. Thanks for looking!
1 Key Blank $20 2 Heater Control Knob $5 3 HVAC Bezel $5 5 Voltage Regulators $5 each 6 Hub Covers $10 each 7 Rear Trunk Lock Spring $10 8 Fuel Lines $5 each 9 2.0 Plenum Brackets $5 for the pair 10 Fuel Injector Supports $5 each 11 2.0 Cold Start Valve Connectors $5 each 12 Belt Cover $5 each 13 2.0 Plenum $40 14 2.0 Fuel Intake Runners $20 per set 15 Starter $10 16 Alternator $25 18 Driver's Side Engine Shroud $150 for all tin 19 Various Engine Shrouds $15 per piece 21 Ignition Coils $10 each 22 Impeller Fan $50 23 More Engine Shrouds $15 per piece 24 Impeller Fan Shround $30 25 Smog Pump Pipe $20 26 Heater Pipe $15 27 Passenger Side Engine Shroud $150 for all tin 28 Defroster Vent $10 29 Leather Steering Wheel Cover $15 30 Side-Shift Transmission $150 31 Headlight Brackets $10 32 Headlight $10 33 Defroster Vent $10 34 Headlight Covers $10 35 Ashtray $15 36 Windshield Wiper Motors $10 each 38 Fuse Panel Board $10 39 Wiper/Turn Signal Stalks $5 40 Headlight Cowl $15 42 Fresh Air Vent Cover $5 43 Non-Fog Light Grille $40 46 Factory Radio $180 48 Chrome Trim $5 per piece 49 Rocker Arm Spacers $5 each 50 Windshield Wipers $5 each 51 Fresh Air Deflector $5 52 Rear View Mirror Base $5 53 Rubber Shift Boot $5 55 Turn Signal Bracket $5 56 Door Handle Bezel $10 57 Pedal Covers $5 each 58 Electric Fuel Pump $10 59 Window Crank $5 60 Trunk Bracket $5 61 Cigarette Lighter $10 (no element) 62 Seat Belt Light $5 63 Trunk Light $10 64 Steelie Lug Bolts $30 for the set 65 HVAC Cables $5 for the set Let's try this link: https://flic.kr/s/aHskwmzgof |
CaesarGz914 |
Mar 16 2016, 10:17 PM
I'm new here ... Group: Members Posts: 0 Joined: 30-December 15 From: Aliso Viejo, CA Member No.: 19,501 Region Association: Southern California |
I'll take the side shift transmission, fuel pump and a passenger side window crank if you have one. Thank you,
Caesar |
Mathman |
Mar 17 2016, 06:37 AM
I'll take the side shift transmission, fuel pump and a passenger side window crank if you have one. Thank you, Caesar Caesar, ZIP code? Please note the window crank I have is technically not 914-correct. It's from a mid-70's VW, but it does fit. Do you still want it? |
Lo-Fi Version | Time is now: 27th September 2024 - 01:21 PM |
