Hershey Parts Thread - What do you need/have? |
stevegm |
Mar 25 2016, 06:32 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
What are you bringing to Hershey, and what do you need?
I am bringing to sell: Weber carbs and manifolds that need to be rebuilt. I am looking to see them cheap. A pair of 944 mirrors A ton of 914 gauges. A few steering wheels A few outer door handles A couple outer mirrors A ton of center pads and trays I am looking to buy: An early rain tray (flat bottom) Any NOS or RD sheet metal 914-6 relay board 914-6 engine harness Rear trunk foam pad New rocker covers (NOS or RD) An early dash (no cracks) A targa pad (no cracks) A targa top front pad (no cracks) |
mskala |
Mar 26 2016, 08:57 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I'll bring these if anybody shows interest beforehand:
1) 911 / 914-6 carb manifolds with ports opened from 32 to 35mm, like if you have an S motor or large displacement motor. Not done by me, good quality (IMG:style_emoticons/default/smile.gif) $200 2) Weber 914-6 IDTP carbs. Made in Italy. Came from running motor. IMO don't need to be rebuilt, just cleaned. No secondary venturis. Partsklassik sells those (short or tall) for $40 each. $800. 3) 911 cylinder heads. Came from running motor. Not right for my build. These are 911.104.302.0R 'k1819n' which is from '72 or '73 911T Mechanical Inj or CIS. Intake ports opened from 30mm to 33mm. Chamfered for some reason, maybe that's needed to use on larger bore. Was told they have 'racing' valve springs. $250. Mark S. |
gereed75 |
Mar 26 2016, 11:06 PM
Senior Member Group: Members Posts: 1,286 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I'll bring these if anybody shows interest beforehand: 1) 911 / 914-6 carb manifolds with ports opened from 32 to 35mm, like if you have an S motor or large displacement motor. Not done by me, good quality (IMG:style_emoticons/default/smile.gif) $200 2) Weber 914-6 IDTP carbs. Made in Italy. Came from running motor. IMO don't need to be rebuilt, just cleaned. No secondary venturis. Partsklassik sells those (short or tall) for $40 each. $800. 3) 911 cylinder heads. Came from running motor. Not right for my build. These are 911.104.302.0R 'k1819n' which is from '72 or '73 911T Mechanical Inj or CIS. Intake ports opened from 30mm to 33mm. Chamfered for some reason, maybe that's needed to use on larger bore. Was told they have 'racing' valve springs. $250. Mark S. I need some carb buckets with the lever clips for a plastic six air cleaner plenum. |
gereed75 |
Mar 28 2016, 09:00 PM
I'll bring these if anybody shows interest beforehand: 1) 911 / 914-6 carb manifolds with ports opened from 32 to 35mm, like if you have an S motor or large displacement motor. Not done by me, good quality (IMG:style_emoticons/default/smile.gif) $200 2) Weber 914-6 IDTP carbs. Made in Italy. Came from running motor. IMO don't need to be rebuilt, just cleaned. No secondary venturis. Partsklassik sells those (short or tall) for $40 each. $800. 3) 911 cylinder heads. Came from running motor. Not right for my build. These are 911.104.302.0R 'k1819n' which is from '72 or '73 911T Mechanical Inj or CIS. Intake ports opened from 30mm to 33mm. Chamfered for some reason, maybe that's needed to use on larger bore. Was told they have 'racing' valve springs. $250. Mark S. I need some carb buckets with the lever clips for a plastic six air cleaner plenum. Oh yea........ I also need the little plastic filler think that goes under the strap/clamp that holds down the gas tank. Thanks |
Lo-Fi Version | Time is now: 27th September 2024 - 02:17 PM |
