Tryin to fit a Mallory Unilite, These things are sure big |
DNHunt |
Oct 2 2004, 05:37 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
And they point the wrong direction.
First you have to beat on the tin so the dizzy cap will fit. Then you have to index the dizzy drive shaft cause the rotor points at I don't know what. The vacuum cannister interferes with the oil filler tube. Kind of a mess Attached image(s) |
DNHunt |
Oct 4 2004, 07:30 AM
I agree it doesn't make any difference where #1 is located as long as the firing order is correct. In my case there was just no room to rotate the distributor body. Between the inlet for the vacuum advance hitting the oil filler neck and the clips that hold the distributor cap on hitting the sheet metal I had about 15 degrees of adjustment. I didn't think that was enough adjustment so I changed it.
Dave |
Lo-Fi Version | Time is now: 27th September 2024 - 12:43 PM |
