Procedure to remove rocker panel covers |
roundboy914 |
Oct 5 2004, 03:49 PM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
So all this talk about the jack stand points, and now i am worried about the amount of dirt and or rust hiding behind my dented side rocker covers, which are also peeling like a mofo.
I removed the phillips head screws around the door openning, are ther more screws that attach underneath? The cover seems loose, but before i start a yankin', i want to insure that i am not missing anything. |
STL914 |
Oct 5 2004, 04:12 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Besides the screws you have already removed, there is one in the front wheel well and one in the rear well, at the ends of the rocker panels. Plus, if you look under the panel you will see 4 or 5 rivets or screws. If rivets, just drill out the heads.
The factory used rivets to secure the panels, but many owners have replaced the rivets with screws to make it easier to remove and replace the panels for maintenance reasons. Hope this helps. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:55 AM |
