Installed my new dash yesterday |
JRust |
May 8 2016, 03:50 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so I finally got around to installing my new 914 rubber reproduced dash. I have to admit I was ready to beat the $hit out of someone but the time I was done. Been quite a while since I removed a dash. The 9 13mm nuts are the worst to get out. I had to remove my radio which normally isn't a problem. The little sleeve it slides into just would not release. A few of the tabs I just couldn't get to. Pretty much destroyed that damn thing taking it out. Not all that big a deal as I want to just install an amp with a blue tooth connection. I never use a radio anymore anyway. The fit of the dash is just a little different than my original. The portion above my gauges where it meets the vinyl under the windshield. Where I notice that the most. I'll get another picture showing it. I took one picture with my new dash in place. At this point I am just glad I am done with the job. Getting those little nut's onto my new dash. Especially the 2 behind the gauges. Those are the worst of them all to feed on there & get tight. At least I won't have to worry about doing it again with my new dash in place right (IMG:style_emoticons/default/evilgrin.gif)
So the end result was just fine but it took me a good 2+ hours of fighting it (IMG:style_emoticons/default/headbang.gif) . Hell I could pull my drive train in a lot less time Attached thumbnail(s) |
Creamsicle New Zealand |
May 9 2016, 02:25 PM
Member Group: Members Posts: 83 Joined: 5-February 15 From: New Zealand Member No.: 18,403 Region Association: Australia and New Zealand |
Nice job well done. Did you replace the vinyl between the dash pad and the windscreen while you had the dash pad out?
If so were did you get the vinyl piece from. I'm about to replace my dash pad and front vinyl piece and looking for as close to original pattern as possible. Steve |
Lo-Fi Version | Time is now: 27th September 2024 - 12:11 PM |
