My 1st 914-frustrated with carb adjustment !, Running out of bourbon-need help |
cashiersjm |
Jul 5 2016, 05:15 PM
Member Group: Members Posts: 40 Joined: 6-December 09 From: Cashiers, North Carolina Member No.: 11,100 Region Association: South East States |
I've read countless posts on adjustments, jets, linkages, etc but I'm new to all of this. Got the car in December 2015, and was told the following: 2.3l, scat c-25 cam. It has the stock non-vacuum distributor w/points, dual weber 40's, ?hex-bar linkage, bursch muffler/no headers. Came w/50 idle jets, 190 ac, 125 mains, f7 e-tubes. I live at elevation 3700'. Have tried f-11 e-tubes, went to 45 idles, ran good at 3500 rpm+, constant pop at lower rpm or flat throttle. Have tried many combos of mains, ac, idles, e-tubes but still pops considerably at flat throttle. Don't have ability to check air-fuel ratio (yet). I'm running out of bourbon-please help (with carbs, have line on more bourbon).
Justinp71 |
Jul 5 2016, 05:55 PM
Senior Member Group: Members Posts: 1,595 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
But- does she got the jack?
One of the things I found is many times people think they have a carb problem and it is really something else. Like an ignition problem or air leak. I just found out on another car of mine that I had a dying coil, when I swear it felt like it was running out of gas on the high end. It does sound like you could have an air leak somewhere. |
Lo-Fi Version | Time is now: 27th September 2024 - 03:27 PM |
