My 1st 914-frustrated with carb adjustment !, Running out of bourbon-need help |
cashiersjm |
Jul 5 2016, 05:15 PM
Member Group: Members Posts: 40 Joined: 6-December 09 From: Cashiers, North Carolina Member No.: 11,100 Region Association: South East States |
I've read countless posts on adjustments, jets, linkages, etc but I'm new to all of this. Got the car in December 2015, and was told the following: 2.3l, scat c-25 cam. It has the stock non-vacuum distributor w/points, dual weber 40's, ?hex-bar linkage, bursch muffler/no headers. Came w/50 idle jets, 190 ac, 125 mains, f7 e-tubes. I live at elevation 3700'. Have tried f-11 e-tubes, went to 45 idles, ran good at 3500 rpm+, constant pop at lower rpm or flat throttle. Have tried many combos of mains, ac, idles, e-tubes but still pops considerably at flat throttle. Don't have ability to check air-fuel ratio (yet). I'm running out of bourbon-please help (with carbs, have line on more bourbon).
cashiersjm |
Jul 6 2016, 03:25 PM
Venturies are 32's, air bypass are in all the way. I'll check for an air leak somewhere. I agree, it sounds like a lean condition. Then when I try to make it richer, it dies at initial throttle. I'll check with the PO and see if he had these problems.
Lo-Fi Version | Time is now: 27th September 2024 - 03:26 PM |
