A little MORE OT - update, Shop Talk, what to build? |
Gunn1 |
Jul 31 2016, 05:33 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Figuring out a floor plan for a new Shop Building. Don't have a unlimited budget so trying to pre plan carefully to get the most value, while not making to many mistakes.
If you were going to build your "dream" shop, or already have one, what do you think should be mandatory, or a feature(s) of yours you wouldn't want to do without. |
Gunn1 |
Aug 2 2016, 05:59 PM
All great suggestions......I hope to incorporate as many of them as I can. The 914-6 may be a little beyond the budget though.
I have the spot picked out, talked to the county regarding set backs, permits and costs. So that part is underway. Next question is, what type of building? there are so many types. pole building, stick built, steel truss, steel paneled corrugated building, Block and many more. Any opinions on which Building type would be your pick? |
My 914 |
Aug 3 2016, 04:28 AM
Casual Member Group: Members Posts: 560 Joined: 23-April 16 From: Massachusetts Member No.: 19,928 Region Association: North East States |
All great suggestions......I hope to incorporate as many of them as I can. The 914-6 may be a little beyond the budget though. I have the spot picked out, talked to the county regarding set backs, permits and costs. So that part is underway. Next question is, what type of building? there are so many types. pole building, stick built, steel truss, steel paneled corrugated building, Block and many more. Any opinions on which Building type would be your pick? Steel beams are expensive but will give you great flexibility. They will eliminate the need for supporting posts in the middle of the floor and give you many options for configuring your space. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:20 AM |
