A little MORE OT - update, Shop Talk, what to build? |
Gunn1 |
Jul 31 2016, 05:33 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Figuring out a floor plan for a new Shop Building. Don't have a unlimited budget so trying to pre plan carefully to get the most value, while not making to many mistakes.
If you were going to build your "dream" shop, or already have one, what do you think should be mandatory, or a feature(s) of yours you wouldn't want to do without. |
Gunn1 |
Aug 2 2016, 05:59 PM
All great suggestions......I hope to incorporate as many of them as I can. The 914-6 may be a little beyond the budget though.
I have the spot picked out, talked to the county regarding set backs, permits and costs. So that part is underway. Next question is, what type of building? there are so many types. pole building, stick built, steel truss, steel paneled corrugated building, Block and many more. Any opinions on which Building type would be your pick? |
6freak |
Aug 3 2016, 11:48 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
All great suggestions......I hope to incorporate as many of them as I can. The 914-6 may be a little beyond the budget though. I have the spot picked out, talked to the county regarding set backs, permits and costs. So that part is underway. Next question is, what type of building? there are so many types. pole building, stick built, steel truss, steel paneled corrugated building, Block and many more. Any opinions on which Building type would be your pick? theres no mention of size you`d like or budget you have, the size of the building will dictate the materials that will work best .JMO MikeC |
Gunn1 |
Aug 3 2016, 12:12 PM
All great suggestions......I hope to incorporate as many of them as I can. The 914-6 may be a little beyond the budget though. I have the spot picked out, talked to the county regarding set backs, permits and costs. So that part is underway. Next question is, what type of building? there are so many types. pole building, stick built, steel truss, steel paneled corrugated building, Block and many more. Any opinions on which Building type would be your pick? theres no mention of size you`d like or budget you have, the size of the building will dictate the materials that will work best .JMO MikeC Size 32x 48 Sidewalls 13' Budget 45,000.00 |
6freak |
Aug 3 2016, 03:06 PM
All great suggestions......I hope to incorporate as many of them as I can. The 914-6 may be a little beyond the budget though. I have the spot picked out, talked to the county regarding set backs, permits and costs. So that part is underway. Next question is, what type of building? there are so many types. pole building, stick built, steel truss, steel paneled corrugated building, Block and many more. Any opinions on which Building type would be your pick? theres no mention of size you`d like or budget you have, the size of the building will dictate the materials that will work best .JMO MikeC Size 32x 48 Sidewalls 13' Budget 45,000.00 thats small enough to use engineered wood trusse`s with no center post`s ..and youll have attic space for storage in the future ..whats going in it? MikeC. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:30 AM |
