> V8/Subie and Automatic tranny suggestions
RacingDreamz
post Sep 2 2016, 01:10 AM
Sorry to rehash old threads again, but we're about to embark on this project soon, I hope. We're looking at possibly either a, turbo'd 2.0 Type 4, Subaru or SBC v8 and an automatic transmission(for the veterans). My question, what transmission would work. I've read that Auto(fwd or 5000 model) will work. Passat trannys are the same as Boxsters, and Subaru fwd trannys.
Any suggestions or recommendations? We hope to do this over the winter.
We'd appreciate any suggestions to help us finally get this done. Thanks (IMG:style_emoticons/default/smile.gif)
veekry9
post Sep 5 2016, 04:59 AM
OldMember
Group: Retired Members
The center diff is custom torque biasing,the front diff any that will handle the power.
This is a great idea,thanks.Paddle shift/Full Auto,good to +1100 hp.
https://www.youtube.com/watch?v=92XzqX1jpgI
This is it,real strong.
Mount the engine/trans normally transverse for a RWD,or,longitudinally for the far-out AWD 914.
Much more work,adapting rear and front diffs into the 914 chassis,front spindles to carry the axle shafts,brakes.
Why,an off-road V8 4x4 914,would be a quaint anachronism at the Paris-Dakar Rally.Fun too.
Simpler to come by than the aircooled Tatra V8,but,much heavier and more powerful.
Painted a flat shade of Sahara,adorned with Hellas and spares,it would make a pretty picture.
Down low with slicks,a twin-turbo would make some quick laps,with a great grip advantage.
BloozeBerry pix.
A rear subframe would definitely be in the works,to carry the loads,now much larger.
Heck,with the chassis already a racer,a migration to full tube is an easy one.
AWD 914...still a great idea Mike,and a mirror of the factory 959.Inspiring.
(IMG:style_emoticons/default/evilgrin.gif)
Let's say you 'wants more gear',and six will do nicely. (IMG:style_emoticons/default/biggrin.gif)
https://www.youtube.com/watch?v=6DzA3T5o1Ac
Shift Points,Ratio Data:
http://www.fiero.nl/forum/Forum3/HTML/000136-5.html
Preventive Maintenance:
https://www.youtube.com/watch?v=D5lNmwd2P4A
https://www.youtube.com/watch?v=PmrMZyQuDCE
Lighting up all the tires in a similar way would make a real nice 'RennWagen',and clothed in 914 guise,an unexpected surprise.
(IMG:style_emoticons/default/happy11.gif)
The Northstar,or Shortstar option,being the least expensive 4-valve option,is narp.
So,a latemodel Porsche V8,is then the other end of the scale,not cheap.
This then,is a premium option,a scored 928 block,made new with wet liners,for a 5.8L displacement,7L,with the 3.75" stroker crank.
http://rennlist.com/forums/928-forum/73700...28-engines.html
RacingDreamz   V8/Subie and Automatic tranny suggestions   Sep 2 2016, 01:10 AM
cali914   Sorry to rehash old threads again, but we're ...   Sep 2 2016, 08:09 AM
Chris H.   Sorry to rehash old threads again, but we're...   Sep 2 2016, 08:46 AM
jmmotorsports   Sorry to rehash old threads again, but we're...   Sep 4 2016, 08:10 AM
jmmotorsports   [quote name='cali914' post='2393210' date='Sep 2 ...   Sep 5 2016, 08:37 AM
Chris914n6   For an auto trans you want to keep it in the same ...   Sep 2 2016, 10:07 AM
Dave_Darling   Keep in mind that modern auto trannies are compute...   Sep 2 2016, 11:14 AM
RacingDreamz   Keep in mind that modern auto trannies are comput...   Sep 2 2016, 08:11 PM
Mike Bellis   Audi FWD automatic trannies are rare in the US. Mu...   Sep 2 2016, 11:25 AM
Andyrew   This is not a winter type project.... there is an ...   Sep 2 2016, 11:27 AM
zach914v8   This is not a winter type project.... there is an...   Sep 2 2016, 11:53 AM
Mike Bellis   Toronado tranny is transverse and would mount the ...   Sep 2 2016, 11:58 AM
zach914v8   Toronado tranny is transverse and would mount the...   Sep 2 2016, 12:03 PM
zach914v8   here is a th425 in a fiero...   Sep 2 2016, 12:14 PM
Chris H.   here is a th425 in a fiero... That's an u...   Sep 2 2016, 02:05 PM
falcor75   Theres a guy in Denmark making a box so that you c...   Sep 2 2016, 12:03 PM
Mike Bellis   I guess you are right. I have seen it mounted tran...   Sep 2 2016, 12:18 PM
zach914v8   I guess you are right. I have seen it mounted tra...   Sep 2 2016, 01:00 PM
Mike Bellis   [quote name='Mike Bellis' post='2393290' date='Se...   Sep 2 2016, 02:00 PM
zach914v8   [quote name='Mike Bellis' post='2393290' date='S...   Sep 2 2016, 02:59 PM
zipedadoo   What about a Fiero trans axle? I have seen v8...   Sep 2 2016, 12:28 PM
tazz9924   What about a Fiero trans axle? I have seen v8...   Sep 4 2016, 11:13 PM
jd74914   I believe the controllers for newer Subaru automat...   Sep 2 2016, 12:50 PM
Mueller   The smartest and easiest choice would be a Subaru ...   Sep 2 2016, 12:56 PM
Cracker   The smartest and easiest choice would be a Subaru...   Oct 25 2016, 04:56 AM
Mike Bellis   Not exactly a donor car, but this is what you need...   Sep 2 2016, 02:13 PM
Mueller   Not exactly a donor car, but this is what you nee...   Sep 2 2016, 04:06 PM
mepstein   If you don't already have good fab skills and ...   Sep 2 2016, 03:12 PM
Andyrew   Now that is an interesting option. Could easily gr...   Sep 2 2016, 03:14 PM
zach914v8   Now that is an interesting option. Could easily g...   Sep 2 2016, 03:52 PM
Mueller   Now that is an interesting option. Could easily ...   Sep 2 2016, 04:11 PM
Mike Bellis   You can see here where the axle output shaft is. a...   Sep 2 2016, 03:39 PM
Mike Bellis   nuther...   Sep 2 2016, 03:40 PM
Mike Bellis   Here's what you should do. (money no object) ...   Sep 2 2016, 03:57 PM
zach914v8   Here's what you should do. (money no object) ...   Sep 2 2016, 04:02 PM
RacingDreamz   Here's what you should do. (money no object) ...   Sep 2 2016, 08:18 PM
Dave_Darling   The Fiero used a transverse FWD drivetrain. Packa...   Sep 2 2016, 05:10 PM
RacingDreamz   I appreciate everyones input. We are purchasing a...   Sep 2 2016, 08:25 PM
veekry9   A mid-engined boonie basher,with a TH-425/TH-3...   Sep 3 2016, 02:38 AM
914forme   :WTF: About 9 years ago I had a serious health i...   Sep 3 2016, 04:40 PM
veekry9   Losing the cast iron monsters,relics of the ...   Sep 3 2016, 05:26 PM
mgp4591   I pulled the SVX trans out of an AWD car and conve...   Sep 3 2016, 09:55 PM
RacingDreamz   I pulled the SVX trans out of an AWD car and conv...   Sep 3 2016, 10:14 PM
mgp4591   I pulled the SVX trans out of an AWD car and con...   Oct 25 2016, 01:44 AM
914forme   If going with the SVX auto read up on mods, it can...   Sep 4 2016, 03:47 AM
RacingDreamz   jmmotorsports, do you have any engine/tranny code ...   Sep 4 2016, 09:38 PM
veekry9   :D The center diff is custom torque biasing,th...   Sep 5 2016, 04:59 AM
veekry9   Well,an option not yet considered here,is the ...   Sep 8 2016, 09:28 AM
RacingDreamz   I got an idea from a friend who didnt mean to expr...   Oct 24 2016, 07:16 PM
messix   I got an idea from a friend who didnt mean to exp...   Oct 24 2016, 08:33 PM
Dave_Darling   Anything can fit if you have a plasma cutter and a...   Oct 24 2016, 08:52 PM
ThePaintedMan   I still know where that FWD auto trans is out of t...   Oct 24 2016, 10:30 PM
RacingDreamz   I still know where that FWD auto trans is out of ...   Oct 24 2016, 10:38 PM
Mike Bellis   944 distributor sticks out in the front of the mot...   Oct 24 2016, 10:54 PM
RacingDreamz   944 distributor sticks out in the front of the mo...   Oct 25 2016, 01:34 AM
Andyrew   944 distributor sticks out in the front of the m...   Oct 25 2016, 08:35 AM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd November 2024 - 01:40 PM
