Compression test Wet and Dry, What do the numbers mean |
catsltd |
Sep 11 2016, 12:43 PM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
I decide to do a compression test since I am going through so much oil.
I warmed car up to about 1/4 on gauge would not go higher sitting on cold day. Petal to floor cranked 5-6 times. 1.Standard compression test cylinder 1 =110 PSI. 2. added a bit of oil cylinder 1 same test 150 PSI. Thats all i did. Seems like rings as was suggested earlier when discussing my oil usage earlier post.??? If rings are there any sort of cheap solutions.???. Car has 100,000 miles on it roughly. Thanks for any suggestions. Money is a issue. Although I am sure just like everything else,once you go to fix 1 problem on a 914,you always end up finding a few more. Car runs great,but using a lot of oil. Grant |
0396 |
Sep 12 2016, 05:32 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
After reading this interesting tread, here's my.02 cents.
With 100,000 miles on the motor and if your only going to do a top end refresh. Its like taking a shower and putting back on the same shorts and possible t shirt. Point is, split the case and refresh everything. |
catsltd |
Sep 13 2016, 07:45 AM
After reading this interesting tread, here's my.02 cents. With 100,000 miles on the motor and if your only going to do a top end refresh. Its like taking a shower and putting back on the same shorts and possible t shirt. Point is, split the case and refresh everything. I guess it all boils down to costs. It also boils down to getting screwed by local shops that dont know shit about a 1.8L motor. I am prepared to spend a bit of money,but not so someone can practice there rebuild skills on my car. If I lived in the USA I would at least have some options from the forum experts. Thanks Grant |
DavidSweden |
Sep 13 2016, 11:15 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
After reading this interesting tread, here's my.02 cents. With 100,000 miles on the motor and if your only going to do a top end refresh. Its like taking a shower and putting back on the same shorts and possible t shirt. Point is, split the case and refresh everything. I guess it all boils down to costs. It also boils down to getting screwed by local shops that dont know shit about a 1.8L motor. I am prepared to spend a bit of money,but not so someone can practice there rebuild skills on my car. If I lived in the USA I would at least have some options from the forum experts. Thanks Grant You can rebuild the bottom end yourse its not hard if you keep it stock. The heads will need a proffesional rebuild Go for it it will be fun |
Lo-Fi Version | Time is now: 27th September 2024 - 01:37 PM |
