> V8/Subie and Automatic tranny suggestions
RacingDreamz
post Sep 2 2016, 01:10 AM
Sorry to rehash old threads again, but we're about to embark on this project soon, I hope. We're looking at possibly either a, turbo'd 2.0 Type 4, Subaru or SBC v8 and an automatic transmission(for the veterans). My question, what transmission would work. I've read that Auto(fwd or 5000 model) will work. Passat trannys are the same as Boxsters, and Subaru fwd trannys.
Any suggestions or recommendations? We hope to do this over the winter.
We'd appreciate any suggestions to help us finally get this done. Thanks (IMG:style_emoticons/default/smile.gif)
mgp4591
post Sep 3 2016, 09:55 PM
I pulled the SVX trans out of an AWD car and converted it to FWD only. I have some measuring to do at RRC to finalize my dimensions for my EG33 swap. Currently the car in on a new rotisserie with me installing the new floor pans and the other needed reinforcements to make it solid enough to handle the power. I'll post my findings after this next weekend but I agree that the Subie/auto trans swap is probably the easiest and less expensive way to go.
RacingDreamz
post Sep 3 2016, 10:14 PM
QUOTE(mgp4591 @ Sep 3 2016, 11:55 PM) *
Thanks. Looking forward to your notes. (IMG:style_emoticons/default/smile.gif)
mgp4591
post Oct 25 2016, 01:44 AM
QUOTE(RacingDreamz @ Sep 3 2016, 10:14 PM) *
I ended up taking the whole month of September off and traveling around the East Coast and surrounding areas, including Octeenerfest and one of my girls getting married. It took a bit longer to get the car up on the rotisserie but the EG33 (SVX) plus the auto trans is roughly 53 inches in length total once the trans was converted to 2wd. There's room for it all but if you go with the 4 banger, you'll still have plenty of power (especially if it's turboed!) and the whole assembly will save you about 6 inches I believe. Good luck!
RacingDreamz   V8/Subie and Automatic tranny suggestions   Sep 2 2016, 01:10 AM
cali914   Sorry to rehash old threads again, but we're ...   Sep 2 2016, 08:09 AM
Chris H.   Sorry to rehash old threads again, but we're...   Sep 2 2016, 08:46 AM
jmmotorsports   Sorry to rehash old threads again, but we're...   Sep 4 2016, 08:10 AM
jmmotorsports   [quote name='cali914' post='2393210' date='Sep 2 ...   Sep 5 2016, 08:37 AM
Chris914n6   For an auto trans you want to keep it in the same ...   Sep 2 2016, 10:07 AM
Dave_Darling   Keep in mind that modern auto trannies are compute...   Sep 2 2016, 11:14 AM
RacingDreamz   Keep in mind that modern auto trannies are comput...   Sep 2 2016, 08:11 PM
Mike Bellis   Audi FWD automatic trannies are rare in the US. Mu...   Sep 2 2016, 11:25 AM
Andyrew   This is not a winter type project.... there is an ...   Sep 2 2016, 11:27 AM
zach914v8   This is not a winter type project.... there is an...   Sep 2 2016, 11:53 AM
Mike Bellis   Toronado tranny is transverse and would mount the ...   Sep 2 2016, 11:58 AM
zach914v8   Toronado tranny is transverse and would mount the...   Sep 2 2016, 12:03 PM
zach914v8   here is a th425 in a fiero...   Sep 2 2016, 12:14 PM
Chris H.   here is a th425 in a fiero... That's an u...   Sep 2 2016, 02:05 PM
falcor75   Theres a guy in Denmark making a box so that you c...   Sep 2 2016, 12:03 PM
Mike Bellis   I guess you are right. I have seen it mounted tran...   Sep 2 2016, 12:18 PM
zach914v8   I guess you are right. I have seen it mounted tra...   Sep 2 2016, 01:00 PM
Mike Bellis   [quote name='Mike Bellis' post='2393290' date='Se...   Sep 2 2016, 02:00 PM
zach914v8   [quote name='Mike Bellis' post='2393290' date='S...   Sep 2 2016, 02:59 PM
zipedadoo   What about a Fiero trans axle? I have seen v8...   Sep 2 2016, 12:28 PM
tazz9924   What about a Fiero trans axle? I have seen v8...   Sep 4 2016, 11:13 PM
jd74914   I believe the controllers for newer Subaru automat...   Sep 2 2016, 12:50 PM
Mueller   The smartest and easiest choice would be a Subaru ...   Sep 2 2016, 12:56 PM
Cracker   The smartest and easiest choice would be a Subaru...   Oct 25 2016, 04:56 AM
Mike Bellis   Not exactly a donor car, but this is what you need...   Sep 2 2016, 02:13 PM
Mueller   Not exactly a donor car, but this is what you nee...   Sep 2 2016, 04:06 PM
mepstein   If you don't already have good fab skills and ...   Sep 2 2016, 03:12 PM
Andyrew   Now that is an interesting option. Could easily gr...   Sep 2 2016, 03:14 PM
zach914v8   Now that is an interesting option. Could easily g...   Sep 2 2016, 03:52 PM
Mueller   Now that is an interesting option. Could easily ...   Sep 2 2016, 04:11 PM
Mike Bellis   You can see here where the axle output shaft is. a...   Sep 2 2016, 03:39 PM
Mike Bellis   nuther...   Sep 2 2016, 03:40 PM
Mike Bellis   Here's what you should do. (money no object) ...   Sep 2 2016, 03:57 PM
zach914v8   Here's what you should do. (money no object) ...   Sep 2 2016, 04:02 PM
RacingDreamz   Here's what you should do. (money no object) ...   Sep 2 2016, 08:18 PM
Dave_Darling   The Fiero used a transverse FWD drivetrain. Packa...   Sep 2 2016, 05:10 PM
RacingDreamz   I appreciate everyones input. We are purchasing a...   Sep 2 2016, 08:25 PM
veekry9   A mid-engined boonie basher,with a TH-425/TH-3...   Sep 3 2016, 02:38 AM
914forme   :WTF: About 9 years ago I had a serious health i...   Sep 3 2016, 04:40 PM
veekry9   Losing the cast iron monsters,relics of the ...   Sep 3 2016, 05:26 PM
mgp4591   I pulled the SVX trans out of an AWD car and conve...   Sep 3 2016, 09:55 PM
RacingDreamz   I pulled the SVX trans out of an AWD car and conv...   Sep 3 2016, 10:14 PM
mgp4591   I pulled the SVX trans out of an AWD car and con...   Oct 25 2016, 01:44 AM
914forme   If going with the SVX auto read up on mods, it can...   Sep 4 2016, 03:47 AM
RacingDreamz   jmmotorsports, do you have any engine/tranny code ...   Sep 4 2016, 09:38 PM
veekry9   :D The center diff is custom torque biasing,th...   Sep 5 2016, 04:59 AM
veekry9   Well,an option not yet considered here,is the ...   Sep 8 2016, 09:28 AM
RacingDreamz   I got an idea from a friend who didnt mean to expr...   Oct 24 2016, 07:16 PM
messix   I got an idea from a friend who didnt mean to exp...   Oct 24 2016, 08:33 PM
Dave_Darling   Anything can fit if you have a plasma cutter and a...   Oct 24 2016, 08:52 PM
ThePaintedMan   I still know where that FWD auto trans is out of t...   Oct 24 2016, 10:30 PM
RacingDreamz   I still know where that FWD auto trans is out of ...   Oct 24 2016, 10:38 PM
Mike Bellis   944 distributor sticks out in the front of the mot...   Oct 24 2016, 10:54 PM
RacingDreamz   944 distributor sticks out in the front of the mo...   Oct 25 2016, 01:34 AM
Andyrew   944 distributor sticks out in the front of the m...   Oct 25 2016, 08:35 AM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd November 2024 - 01:58 PM
