How Do You Tighten Down the Dash Top, ...where are the access points? |
7TPorsh |
Oct 31 2016, 10:00 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I spent the weekend getting my new 914rubber dash top vinyl in. I'm using the early brickmold pattern instead of smooth. i didn't like the previous smooth; it was too shiny.
So vinyl is down and defroster vents are in. Now I'm trying to line up and get the dash on. It clips in the holes but..... where do i access the bottom of the plastic bolts so I can tighten the dash down so there's no gap? It seems it was never "bolted". |
7TPorsh |
Nov 1 2016, 10:50 AM
I managed to get to the two on each side of the ashtray. But the two in the back for the "hood" don't look like the picture.
There is very little gap to even get the nut in there much less line it up or turn it. My dash is where the green line is....I can barely even see the bolts. I'll take pics tonight but here is the sample picture with comments. ....also I have an early dash so no left side vent. That bolt is totally hidden. |
dlkawashima |
Nov 1 2016, 11:40 AM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
I managed to get to the two on each side of the ashtray. But the two in the back for the "hood" don't look like the picture. There is very little gap to even get the nut in there much less line it up or turn it. My dash is where the green line is....I can barely even see the bolts. I'll take pics tonight but here is the sample picture with comments. ....also I have an early dash so no left side vent. That bolt is totally hidden. I used a 13mm cone wrench for the two nuts in the hood. For the nut on the far left side of the dash, try a "thumbwheel" or "finger" ratchet or a mini ratchet with a flex head. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:26 AM |
