My attempt to Subaru AWD to 2WD, Another option? |
914pipe |
Nov 4 2016, 02:02 PM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
Credit and Inspiration to this thread: http://www.914world.com/bbs2/index.php?sho...104513&st=0
This is my attempt to convert from Subaru AWD to 2WD tranny using their own internals. So…! I pulled the engine out and I’m going for a Subaru tranny. I pulled out the transmission cover and removed the differential. I put the whole differential in a flat surface and make 2 tag welds to fix in position the whole differential. I did a test fit on the transmission, to be sure that the gears did not moved during the tag welding. Did the necessary measurements to cut the differential. Then proceeded to cut the differential (had to pullout the bearing first). |
Mark Henry |
Nov 4 2016, 05:21 PM
Cool!
I know there is a company in aussie that sells this as a kit. Good stuff but not cheap. Can't remember the name of hand. Keep the pics coming and explain to the unwashed masses why you have to do this. (IMG:style_emoticons/default/smile.gif) |
mgp4591 |
Nov 4 2016, 05:26 PM
914 Guru Group: Members Posts: 5,481 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Cool! I know there is a company in aussie that sells this as a kit. Good stuff but not cheap. Can't remember the name of hand. Keep the pics coming and explain to the unwashed masses why you have to do this. (IMG:style_emoticons/default/smile.gif) Because a Subaru trans with a Subaru engine is a no brainer.... (IMG:style_emoticons/default/shades.gif) |
Mark Henry |
Nov 4 2016, 05:33 PM
Cool! I know there is a company in aussie that sells this as a kit. Good stuff but not cheap. Can't remember the name of hand. Keep the pics coming and explain to the unwashed masses why you have to do this. (IMG:style_emoticons/default/smile.gif) Because a Subaru trans with a Subaru engine is a no brainer.... (IMG:style_emoticons/default/shades.gif) I mean explain why does he have to do this mod, many won't know why. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 23rd November 2024 - 08:44 AM |
