My attempt to Subaru AWD to 2WD, Another option? |
914pipe |
Nov 4 2016, 02:02 PM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
Credit and Inspiration to this thread: http://www.914world.com/bbs2/index.php?sho...104513&st=0
This is my attempt to convert from Subaru AWD to 2WD tranny using their own internals. So…! I pulled the engine out and I’m going for a Subaru tranny. I pulled out the transmission cover and removed the differential. I put the whole differential in a flat surface and make 2 tag welds to fix in position the whole differential. I did a test fit on the transmission, to be sure that the gears did not moved during the tag welding. Did the necessary measurements to cut the differential. Then proceeded to cut the differential (had to pullout the bearing first). |
Mark Henry |
Nov 4 2016, 05:21 PM
Cool!
I know there is a company in aussie that sells this as a kit. Good stuff but not cheap. Can't remember the name of hand. Keep the pics coming and explain to the unwashed masses why you have to do this. (IMG:style_emoticons/default/smile.gif) |
914pipe |
Nov 4 2016, 06:50 PM
Cool! I know there is a company in aussie that sells this as a kit. Good stuff but not cheap. Can't remember the name of hand. Keep the pics coming and explain to the unwashed masses why you have to do this. (IMG:style_emoticons/default/smile.gif) Smallcar, Subarugears and bremarauto are some of those companies that make the kits... and also there is a guy from this forum that makes it too with a more reasonable and affordable price. The lock kit will cost about $200 dollars and I was not willing to pay that for something that I can do for free. Maybe you would have to pay for the Tig welding. The main reason for this mod is to convert this transmission from 4wheel drive to front wheel drive.... And the backing plate is about $200 dollars more. No way!!!! I'm going to do my own. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 23rd November 2024 - 11:20 AM |
