Need to Power Car Radio on the Bench Top, 110v to 12v converter |
gcrotvik |
Dec 31 2016, 02:44 PM
Member Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Trying to find a 110 volt power supply to power a 12 volt car radio for installation and sound testing. Looked on-line and need a recomendation as to what to use/buy.
Thanks, Greg |
stugray |
Jan 1 2017, 01:03 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I use a standard battery charger for things like that, but what do I know, I'm just an electrical engineer.....
If worried about overvoltage or noise, put a battery on it at the same time. I Also use PC power supplies, but when using them out of the PC case, you will need to short (temporarily) the blue wire to the chassis to get it to turn on. I found some aviation quality adjustable DC power supplies at a salvage yard & bought two for $40. (they are worth about $1200 ea.) |
Mark Henry |
Jan 1 2017, 01:19 PM
I use a standard battery charger for things like that, but what do I know, I'm just an electrical engineer..... If worried about overvoltage or noise, put a battery on it at the same time. Thanks Stu Been working on aircooled cars since I was a teen, to troubleshoot all electrical you can power everything by using a battery charger. You do need to pull the power wire off the coil or you will fry the points and some aftermarket pickups like the pertronix. QUOTE I Also use PC power supplies, but when using them out of the PC case, you will need to short (temporarily) the blue wire to the chassis to get it to turn on. Or just twist it onto a ground wire (IMG:style_emoticons/default/wink.gif) BTW I wasn't being pissy, just I see no reason to tell someone to go spend money when they likely have something that does the job right in front of them. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:26 AM |
