Need to Power Car Radio on the Bench Top, 110v to 12v converter |
gcrotvik |
Dec 31 2016, 02:44 PM
Member Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Trying to find a 110 volt power supply to power a 12 volt car radio for installation and sound testing. Looked on-line and need a recomendation as to what to use/buy.
Thanks, Greg |
gcrotvik |
Jan 1 2017, 02:15 PM
Thanks for the feedback. My stereo install isn't an audiophile setup but more than the standard 2 speaker in the stock location setup. I'm testing secondary speaker and hidden satellite antenna locations for a second car.
I was also hoping to find a power supply to mimic a fully charged battery to power my chassis harness for testing of all components while installing it (turn signals, headlight motors, fans, etc.). I found many 110VAC to 12VDC power supplies on-line but wasn't sure they would suit my needs as I didn't want to blow up my chassis harness during testing. I'm a network and software engineer, not an electrical engineer so I'm out of my element with power. Here is the unit I found: http://www.ebay.com/itm/282264455526?_trks...K%3AMEBIDX%3AIT Greg |
stugray |
Jan 1 2017, 02:38 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Thanks for the feedback. My stereo install isn't an audiophile setup but more than the standard 2 speaker in the stock location setup. I'm testing secondary speaker and hidden satellite antenna locations for a second car. I was also hoping to find a power supply to mimic a fully charged battery to power my chassis harness for testing of all components while installing it (turn signals, headlight motors, fans, etc.). I found many 110VAC to 12VDC power supplies on-line but wasn't sure they would suit my needs as I didn't want to blow up my chassis harness during testing. I'm a network and software engineer, not an electrical engineer so I'm out of my element with power. Here is the unit I found: http://www.ebay.com/itm/282264455526?_trks...K%3AMEBIDX%3AIT Greg That one looks good. I had to check because some LED drivers are constant current. This one appears to be constant voltage (current varies to whatever up to 10A), so it should work perfectly. |
gcrotvik |
Jan 1 2017, 02:43 PM
Thanks for the feedback. My stereo install isn't an audiophile setup but more than the standard 2 speaker in the stock location setup. I'm testing secondary speaker and hidden satellite antenna locations for a second car. I was also hoping to find a power supply to mimic a fully charged battery to power my chassis harness for testing of all components while installing it (turn signals, headlight motors, fans, etc.). I found many 110VAC to 12VDC power supplies on-line but wasn't sure they would suit my needs as I didn't want to blow up my chassis harness during testing. I'm a network and software engineer, not an electrical engineer so I'm out of my element with power. Here is the unit I found: http://www.ebay.com/itm/282264455526?_trks...K%3AMEBIDX%3AIT Greg That one looks good. I had to check because some LED drivers are constant current. This one appears to be constant voltage (current varies to whatever up to 10A), so it should work perfectly. Thank you! |
Lo-Fi Version | Time is now: 27th September 2024 - 09:31 AM |
