Need Advice: Front end/steering column shakes a little bit on roughed/un-even road |
ndfrigi |
Jan 13 2017, 05:24 PM
Advanced Member Group: Members Posts: 2,953 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Any idea what are the things I should check? if I drove to a roughed/uneven road I get this little shaking on my front/end or steering column.
new 4 tires and balanced last year and has only less 300 miles driven. It was not aligned last year since the shop where I bought the tires does not want to align it. So I thought the shaking can be fix after alignment. So today it was aligned but still shaking on roughed or uneven roads. Thank you! |
Steve |
Jan 13 2017, 06:44 PM
914 Guru Group: Members Posts: 5,685 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Can you move the steering wheel up and down? If so if its a 75 or 76 there is a shim you can buy from Pelican to solve the problem. Earlier car will need a new bearing.
If you can't move the steering wheel up and down then you have some other problem. Loose steering knuckle, bushings, etc. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:29 AM |
