Engine run on, Don't know what else to try |
oakdalecurtis |
Mar 5 2017, 05:47 AM
Oakdalecurtis Group: Members Posts: 1,336 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
76 2.0, 120k miles, all stock engine parts except for Crane Ignition. Engine runs on after shutdown for 3 to 5 seconds. All engine parts working, thermostat, aux air regulator, no vacuum leaks, motor runs beautifully and pulls hard, engine idles after warmup at about 600 rpm. I tried adding a diode to the lead from the alternator to the generator light, that made no difference to stopping the run on after shutdown. Any other ideas to suggest that might fix it? (besides popping the clutch to stop the engine)
oakdalecurtis |
Mar 5 2017, 01:18 PM
It runs on even after short drives. The temp outside has been cool and I don't think the engine is running hot. Since I removed the rain tray the engine has been running cooler than ever. The cylinder and oil temps seem fine. Will check timing before smog check and go from there.
Lo-Fi Version | Time is now: 27th September 2024 - 06:36 AM |
