If you fail the "bounce test" how screwed are you? |
McLovin |
Mar 6 2017, 11:02 PM
Member Group: Members Posts: 110 Joined: 31-August 16 From: Tallahassee, FL Member No.: 20,360 Region Association: South East States |
Question for the group:
The bounce test is when you open all the doors, take off the roof, and jump up and down on the passenger side. Then you try to close the doors and see if they close easily. Suppose your car fails the bounce test. It's clear that the car would need major surgery in the form of rust repair and reinforcing. But if you do the bounce test and fail, did you just bend the car? Is straightening it as simple as putting a jack under it? Or would you need to do something more elaborate? Has anyone been down that road? Thanks, Mclovin |
Rand |
Mar 6 2017, 11:11 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Slow down gunn. Only dorks jump up and down
If you want to get serious: Roof off, doors closed (because duh you need that for the gap). Feel the door gap as you change your weight on the passenger rail. Put your thumb over the gap and feel for change. |
McLovin |
Mar 7 2017, 12:56 AM
Slow down gunn. Only dorks jump up and down If you want to get serious: Roof off, doors closed (because duh you need that for the gap). Feel the door gap as you change your weight on the passenger rail. Put your thumb over the gap and feel for change. Sounds like a good way to test the area without bending it out of shape. So there would be no reason to need to bend it back. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:39 AM |
