HELP! No spark, Replaced the Mallory module |
jeffdon |
May 15 2017, 02:46 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I figured I had fried my Mallory optical module with a battery charger, and so I just replaced it with brand new. Still no spark. With key on, I getting 12v at the neg side of the coil and on the primary. I had my fuel pump powered off the pos side of the coil, and was seeing a V drop down to just under 6 when that was on it. Moved the power source to the relay board. Now seeing 12v. Still no spark.
What the hell else should I check? Could I have fried the module on first power up? (IMG:style_emoticons/default/headbang.gif) |
Dave_Darling |
May 15 2017, 03:18 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
What triggers your spark? Regular points? Pertronix? Other?
Try swapping in points and condenser (or a new set if you're using points) and see what happens. --DD |
jeffdon |
May 15 2017, 03:33 PM
What triggers your spark? Regular points? Pertronix? Other? Try swapping in points and condenser (or a new set if you're using points) and see what happens. --DD The mallory dizzy is the optical pickup kind. NEver had points. I was going to swap in my old pertronix equiped 009, but it appears one of the dizzy cap clips has gone missing. |
poorsche914 |
May 15 2017, 04:38 PM
T4 Supercharged Group: Members Posts: 3,121 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Have you tried the Unilite Test Procedure ?
I have fried a unit on first power up. Irritating to say the least! (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/driving.gif) |
jeffdon |
May 15 2017, 04:57 PM
Have you tried the Unilite Test Procedure ? I have fried a unit on first power up. Irritating to say the least! (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/driving.gif) Yeah, and it appears to be non-operative. Is Mallory also maybe shipping bad modules? For what its worth, my old 009 with pertronix aint working either. |
poorsche914 |
May 15 2017, 05:41 PM
Yeah, and it appears to be non-operative. Is Mallory also maybe shipping bad modules? For what its worth, my old 009 with pertronix aint working either. Last time I thought a module went bad it ended up being my coil (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 11:17 PM |
