HELP! No spark, Replaced the Mallory module |
jeffdon |
May 15 2017, 02:46 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I figured I had fried my Mallory optical module with a battery charger, and so I just replaced it with brand new. Still no spark. With key on, I getting 12v at the neg side of the coil and on the primary. I had my fuel pump powered off the pos side of the coil, and was seeing a V drop down to just under 6 when that was on it. Moved the power source to the relay board. Now seeing 12v. Still no spark.
What the hell else should I check? Could I have fried the module on first power up? (IMG:style_emoticons/default/headbang.gif) |
jeffdon |
May 15 2017, 08:53 PM
Got her running with the 009 and points. Looks like I may have mistaken the power wire to the dizzy with the tach wire. Old red and old purple look the same.
Are points availible for the mallory dizzy? I am kinda fed up with the optical pick ups. |
Dave_Darling |
May 15 2017, 09:14 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Looks like I may have mistaken the power wire to the dizzy with the tach wire. Old red and old purple look the same. Ugh! Yeah, been there done that. I always remember that the wire that carries the power is thicker, and the one that carries the signal is thinner. --DD |
jeffdon |
May 15 2017, 09:23 PM
Looks like I may have mistaken the power wire to the dizzy with the tach wire. Old red and old purple look the same. Ugh! Yeah, been there done that. I always remember that the wire that carries the power is thicker, and the one that carries the signal is thinner. --DD Yeah, I should have realized that. Better marking of things is called for. Wonder if my mallory is NOT fried? |
Lo-Fi Version | Time is now: 26th September 2024 - 11:19 PM |
