Hard starting, low hunting idle, until it warms up? |
Geezer914 |
May 27 2017, 09:30 AM
Geezer914 Group: Members Posts: 1,660 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
1975 1.8L Ljet injection. Car is hard to start. It takes 3-4 tries and some time a shot of starting fluid. Fuel pressure gauge reads 30 lbs. in engine compartment. The rpm rises to 1800 rpm for about 15 seconds, then the idle hunts between 500 rpm and almost stalling out. After the engine warms up it runs and starts as normal. Vacuum hoses are tight. Comments? (IMG:style_emoticons/default/confused24.gif)
Beebo Kanelle |
May 27 2017, 09:50 AM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Gasoline filter will allow pressure to build, but will limit flow. Check the injectors and make sure they are clean and flow properly.
Lo-Fi Version | Time is now: 27th September 2024 - 10:19 AM |
